Подскажите пожалуйста как настроить подключение wirenboard к openhub, а конкретно что вписать в настройки ниже (cfg файл openHAB’a).
пусть openHAB 192.168.1.2, wirenboard 192.168.1.3
В нём 2 раздела MQTT:
MQTT Persistence
Name of the broker as defined in the section MQTT Transport
mqtt-persistence:broker=
The MQTT topic to which the persistence messages should be sent.
mqtt-persistence:topic=
A string representing the persistence message content.
mqtt-persistence:message=
и второй
MQTT Transport
Define your MQTT broker connections here for use in the MQTT Binding or MQTT
Persistence bundles. Replace <broker> with a id you choose.
URL to the MQTT broker, e.g. tcp://localhost:1883 or ssl://localhost:8883
#mqtt:<broker>.url=tcp://<host>:1883
Optional. Client id (max 23 chars) to use when connecting to the broker.
If not provided a default one is generated.
#mqtt:<broker>.clientId=<clientId>
Optional. User id to authenticate with the broker.
mqtt:<broker>.user=<user>
Optional. Password to authenticate with the broker.
#mqtt:<broker>.pwd=<password>
Optional. Set the quality of service level for sending messages to this broker.
Possible values are 0 (Deliver at most once),1 (Deliver at least once) or 2
(Deliver exactly once). Defaults to 0.
#mqtt:<broker>.qos=<qos>
Optional. True or false. Defines if the broker should retain the messages sent to
it. Defaults to false.
#mqtt:<broker>.retain=<retain>
Optional. True or false. Defines if messages are published asynchronously or
synchronously. Defaults to true.
#mqtt:<broker>.async=<async>
Optional. Defines the last will and testament that is sent when this client goes offline
Format: topic:message:qos:retained <br/>
#mqtt:<broker>.lwt=<last will definition>
