Выше я написал, что с новой версией confed у меня стало все нормально. С тех пор все так и работает нормально.
Погорячился я про “через раз”. Появляется постоянно. В консоль браузера выплевывает вот это:
MQTT response with unexpected id:
Object {
payload: "{"id":1,"result":[{"title":"Network Interface Configuration","description":"Specifies network configuration of the system","configPath":"/etc/network/interfaces","schemaPath":"/usr/share/wb-mqtt-confed/schemas/interfaces.schema.json"},{"title":"NTP configuration","description":"Specifies NTP network time sync daemon configuration","configPath":"/etc/ntp.conf","schemaPath":"/usr/share/wb-mqtt-confed/schemas/ntp.schema.json"},{"title":"ADC Driver Configuration","description":"Analog inputs configuration","configPath":"/etc/wb-homa-adc.conf","schemaPath":"/usr/share/wb-mqtt-confed/schemas/wb-homa-adc.schema.json"},{"title":"GPIO Driver Configuration","description":"Digital inputs and outputs configuration","configPath":"/etc/wb-homa-gpio.conf","schemaPath":"/usr/share/wb-mqtt-confed/schemas/wb-homa-gpio.schema.json"},{"title":"MQTT History Configuration","description":"","configPath":"/etc/wb-mqtt-db.conf","schemaPath":"/usr/share/wb-mqtt-confed/schemas/wb-mqtt-db.schema.json"},{"title":"Serial Device Driver Configuration","description":"Lists devices attached to RS-485 ports","configPath":"/etc/wb-mqtt-serial.conf","schemaPath":"/usr/share/wb-mqtt-confed/schemas/wb-mqtt-serial.schema.json"},{"title":"Alarm Configuration","description":"Lists alarms","configPath":"/etc/wb-rules/alarms.conf","schemaPath":"/usr/share/wb-mqtt-confed/schemas/alarms.schema.json"}]}",
qos: 1,
retained: false,
topic: "/rpc/v1/confed/Editor/List/contactless-ahQ4xZb1AB/reply"
Дебаг лог из /var/messages
Feb 22 13:15:44 wirenboard-ABOON5CN daemon.info wb-mqtt-confed[21073]: [MQTT] DEBUG: [pinger] keepalive sending ping
Feb 22 13:15:44 wirenboard-ABOON5CN daemon.info wb-mqtt-confed[21073]: [MQTT] DEBUG: [net] Received Message
Feb 22 13:15:44 wirenboard-ABOON5CN daemon.info wb-mqtt-confed[21073]: [MQTT] DEBUG: [net] logic got msg on ibound
Feb 22 13:15:44 wirenboard-ABOON5CN daemon.info wb-mqtt-confed[21073]: [MQTT] DEBUG: [net] received pingresp
Feb 22 13:15:44 wirenboard-ABOON5CN daemon.info wb-mqtt-confed[21073]: [MQTT] DEBUG: [net] logic waiting for msg on ibound
Feb 22 13:15:54 wirenboard-ABOON5CN daemon.info wb-mqtt-confed[21073]: [MQTT] DEBUG: [pinger] keepalive sending ping
Feb 22 13:15:54 wirenboard-ABOON5CN daemon.info wb-mqtt-confed[21073]: [MQTT] DEBUG: [net] Received Message
Feb 22 13:15:54 wirenboard-ABOON5CN daemon.info wb-mqtt-confed[21073]: [MQTT] DEBUG: [net] logic got msg on ibound
Feb 22 13:15:54 wirenboard-ABOON5CN daemon.info wb-mqtt-confed[21073]: [MQTT] DEBUG: [net] received pingresp
Feb 22 13:15:54 wirenboard-ABOON5CN daemon.info wb-mqtt-confed[21073]: [MQTT] DEBUG: [net] logic waiting for msg on ibound
Feb 22 13:16:04 wirenboard-ABOON5CN daemon.info wb-mqtt-confed[21073]: [MQTT] DEBUG: [pinger] keepalive sending ping
Feb 22 13:16:04 wirenboard-ABOON5CN daemon.info wb-mqtt-confed[21073]: [MQTT] DEBUG: [net] Received Message
Feb 22 13:16:04 wirenboard-ABOON5CN daemon.info wb-mqtt-confed[21073]: [MQTT] DEBUG: [net] logic got msg on ibound
Feb 22 13:16:04 wirenboard-ABOON5CN daemon.info wb-mqtt-confed[21073]: [MQTT] DEBUG: [net] received pingresp
Feb 22 13:16:04 wirenboard-ABOON5CN daemon.info wb-mqtt-confed[21073]: [MQTT] DEBUG: [net] logic waiting for msg on ibound
Feb 22 13:16:14 wirenboard-ABOON5CN daemon.info wb-mqtt-confed[21073]: [MQTT] DEBUG: [pinger] keepalive sending ping
Feb 22 13:16:14 wirenboard-ABOON5CN daemon.info wb-mqtt-confed[21073]: [MQTT] DEBUG: [net] Received Message
Feb 22 13:16:14 wirenboard-ABOON5CN daemon.info wb-mqtt-confed[21073]: [MQTT] DEBUG: [net] logic got msg on ibound
Feb 22 13:16:14 wirenboard-ABOON5CN daemon.info wb-mqtt-confed[21073]: [MQTT] DEBUG: [net] received pingresp
Feb 22 13:16:14 wirenboard-ABOON5CN daemon.info wb-mqtt-confed[21073]: [MQTT] DEBUG: [net] logic waiting for msg on ibound
Feb 22 13:16:22 wirenboard-ABOON5CN daemon.info wb-mqtt-confed[21073]: [MQTT] DEBUG: [net] Received Message
Feb 22 13:16:22 wirenboard-ABOON5CN daemon.info wb-mqtt-confed[21073]: [MQTT] DEBUG: [net] logic got msg on ibound
Feb 22 13:16:22 wirenboard-ABOON5CN daemon.info wb-mqtt-confed[21073]: [MQTT] DEBUG: [net] received publish, msgId: 1
Feb 22 13:16:22 wirenboard-ABOON5CN daemon.info wb-mqtt-confed[21073]: [MQTT] DEBUG: [net] putting msg on onPubChan
Feb 22 13:16:22 wirenboard-ABOON5CN daemon.info wb-mqtt-confed[21073]: [MQTT] DEBUG: [net] done putting msg on incomingPubChan
Feb 22 13:16:22 wirenboard-ABOON5CN daemon.info wb-mqtt-confed[21073]: [MQTT] DEBUG: [net] putting puback msg on obound
Feb 22 13:16:22 wirenboard-ABOON5CN daemon.info wb-mqtt-confed[21073]: [MQTT] DEBUG: [net] done putting puback msg on obound
Feb 22 13:16:22 wirenboard-ABOON5CN daemon.info wb-mqtt-confed[21073]: DEBUG: GOT MESSAGE: /rpc/v1/confed/Editor/List/contactless-ahQ4xZb1AB --- {"id":1,"params":{}}
Feb 22 13:16:22 wirenboard-ABOON5CN daemon.info wb-mqtt-confed[21073]: [MQTT] DEBUG: [net] logic waiting for msg on ibound
Feb 22 13:16:22 wirenboard-ABOON5CN daemon.info wb-mqtt-confed[21073]: DEBUG: PUB: /rpc/v1/confed/Editor/List/contactless-ahQ4xZb1AB/reply -> {"id":1,"result":[{"title":"Network Interface Configuration","description":"Specifies network configuration of the system","configPath":"/etc
Feb 22 13:16:22 wirenboard-ABOON5CN daemon.info wb-mqtt-confed[21073]: [MQTT] DEBUG: [net] obound priority msg to write, type *packets.PubackPacket
Feb 22 13:16:22 wirenboard-ABOON5CN daemon.info wb-mqtt-confed[21073]: [MQTT] DEBUG: [net] outgoing waiting for an outbound message
Feb 22 13:16:22 wirenboard-ABOON5CN daemon.info wb-mqtt-confed[21073]: [MQTT] DEBUG: [client] enter Publish
Feb 22 13:16:22 wirenboard-ABOON5CN daemon.info wb-mqtt-confed[21073]: [MQTT] DEBUG: [client] sending publish message, topic: /rpc/v1/confed/Editor/List/contactless-ahQ4xZb1AB/reply
Feb 22 13:16:22 wirenboard-ABOON5CN daemon.info wb-mqtt-confed[21073]: [MQTT] DEBUG: [net] received puback, id: 1
Feb 22 13:16:22 wirenboard-ABOON5CN daemon.info wb-mqtt-confed[21073]: [MQTT] DEBUG: [net] obound wrote msg, id: 1
Feb 22 13:16:32 wirenboard-ABOON5CN daemon.info wb-mqtt-confed[21073]: [MQTT] DEBUG: [pinger] keepalive sending ping
Feb 22 13:16:32 wirenboard-ABOON5CN daemon.info wb-mqtt-confed[21073]: [MQTT] DEBUG: [net] Received Message
Feb 22 13:16:32 wirenboard-ABOON5CN daemon.info wb-mqtt-confed[21073]: [MQTT] DEBUG: [net] logic got msg on ibound
Feb 22 13:16:32 wirenboard-ABOON5CN daemon.info wb-mqtt-confed[21073]: [MQTT] DEBUG: [net] received pingresp
Feb 22 13:16:32 wirenboard-ABOON5CN daemon.info wb-mqtt-confed[21073]: [MQTT] DEBUG: [net] logic waiting for msg on ibound
Feb 22 13:16:42 wirenboard-ABOON5CN daemon.info wb-mqtt-confed[21073]: [MQTT] DEBUG: [pinger] keepalive sending ping
Feb 22 13:16:42 wirenboard-ABOON5CN daemon.info wb-mqtt-confed[21073]: [MQTT] DEBUG: [net] Received Message
Feb 22 13:16:42 wirenboard-ABOON5CN daemon.info wb-mqtt-confed[21073]: [MQTT] DEBUG: [net] logic got msg on ibound
Feb 22 13:16:42 wirenboard-ABOON5CN daemon.info wb-mqtt-confed[21073]: [MQTT] DEBUG: [net] received pingresp
Feb 22 13:16:42 wirenboard-ABOON5CN daemon.info wb-mqtt-confed[21073]: [MQTT] DEBUG: [net] logic waiting for msg on ibound
Feb 22 13:16:52 wirenboard-ABOON5CN daemon.info wb-mqtt-confed[21073]: [MQTT] DEBUG: [pinger] keepalive sending ping
Feb 22 13:16:52 wirenboard-ABOON5CN daemon.info wb-mqtt-confed[21073]: [MQTT] DEBUG: [net] Received Message
Feb 22 13:16:52 wirenboard-ABOON5CN daemon.info wb-mqtt-confed[21073]: [MQTT] DEBUG: [net] logic got msg on ibound
Feb 22 13:16:52 wirenboard-ABOON5CN daemon.info wb-mqtt-confed[21073]: [MQTT] DEBUG: [net] received pingresp
Feb 22 13:16:52 wirenboard-ABOON5CN daemon.info wb-mqtt-confed[21073]: [MQTT] DEBUG: [net] logic waiting for msg on ibound
Feb 22 13:17:02 wirenboard-ABOON5CN daemon.info wb-mqtt-confed[21073]: [MQTT] DEBUG: [pinger] keepalive sending ping
Feb 22 13:17:02 wirenboard-ABOON5CN daemon.info wb-mqtt-confed[21073]: [MQTT] DEBUG: [net] Received Message
Feb 22 13:17:02 wirenboard-ABOON5CN daemon.info wb-mqtt-confed[21073]: [MQTT] DEBUG: [net] logic got msg on ibound
Feb 22 13:17:02 wirenboard-ABOON5CN daemon.info wb-mqtt-confed[21073]: [MQTT] DEBUG: [net] received pingresp
Feb 22 13:17:02 wirenboard-ABOON5CN daemon.info wb-mqtt-confed[21073]: [MQTT] DEBUG: [net] logic waiting for msg on ibound
Feb 22 13:17:12 wirenboard-ABOON5CN daemon.info wb-mqtt-confed[21073]: [MQTT] DEBUG: [pinger] keepalive sending ping
Feb 22 13:17:12 wirenboard-ABOON5CN daemon.info wb-mqtt-confed[21073]: [MQTT] DEBUG: [net] Received Message
Feb 22 13:17:12 wirenboard-ABOON5CN daemon.info wb-mqtt-confed[21073]: [MQTT] DEBUG: [net] logic got msg on ibound
Feb 22 13:17:12 wirenboard-ABOON5CN daemon.info wb-mqtt-confed[21073]: [MQTT] DEBUG: [net] received pingresp
Feb 22 13:17:12 wirenboard-ABOON5CN daemon.info wb-mqtt-confed[21073]: [MQTT] DEBUG: [net] logic waiting for msg on ibound
Feb 22 13:17:22 wirenboard-ABOON5CN daemon.info wb-mqtt-confed[21073]: [MQTT] DEBUG: [pinger] keepalive sending ping
Feb 22 13:17:22 wirenboard-ABOON5CN daemon.info wb-mqtt-confed[21073]: [MQTT] DEBUG: [net] Received Message
Feb 22 13:17:22 wirenboard-ABOON5CN daemon.info wb-mqtt-confed[21073]: [MQTT] DEBUG: [net] logic got msg on ibound
Feb 22 13:17:22 wirenboard-ABOON5CN daemon.info wb-mqtt-confed[21073]: [MQTT] DEBUG: [net] received pingresp
Feb 22 13:17:22 wirenboard-ABOON5CN daemon.info wb-mqtt-confed[21073]: [MQTT] DEBUG: [net] logic waiting for msg on ibound
Feb 22 13:17:32 wirenboard-ABOON5CN daemon.info wb-mqtt-confed[21073]: [MQTT] DEBUG: [pinger] keepalive sending ping
Feb 22 13:17:32 wirenboard-ABOON5CN daemon.info wb-mqtt-confed[21073]: [MQTT] DEBUG: [net] Received Message
Feb 22 13:17:32 wirenboard-ABOON5CN daemon.info wb-mqtt-confed[21073]: [MQTT] DEBUG: [net] logic got msg on ibound
Feb 22 13:17:32 wirenboard-ABOON5CN daemon.info wb-mqtt-confed[21073]: [MQTT] DEBUG: [net] received pingresp
Feb 22 13:17:32 wirenboard-ABOON5CN daemon.info wb-mqtt-confed[21073]: [MQTT] DEBUG: [net] logic waiting for msg on ibound
Feb 22 13:17:42 wirenboard-ABOON5CN daemon.info wb-mqtt-confed[21073]: [MQTT] DEBUG: [pinger] keepalive sending ping
Feb 22 13:17:42 wirenboard-ABOON5CN daemon.info wb-mqtt-confed[21073]: [MQTT] DEBUG: [net] Received Message
Feb 22 13:17:42 wirenboard-ABOON5CN daemon.info wb-mqtt-confed[21073]: [MQTT] DEBUG: [net] logic got msg on ibound
Feb 22 13:17:42 wirenboard-ABOON5CN daemon.info wb-mqtt-confed[21073]: [MQTT] DEBUG: [net] received pingresp
Feb 22 13:17:42 wirenboard-ABOON5CN daemon.info wb-mqtt-confed[21073]: [MQTT] DEBUG: [net] logic waiting for msg on ibound
Feb 22 13:17:52 wirenboard-ABOON5CN daemon.info wb-mqtt-confed[21073]: [MQTT] DEBUG: [pinger] keepalive sending ping
Feb 22 13:17:52 wirenboard-ABOON5CN daemon.info wb-mqtt-confed[21073]: [MQTT] DEBUG: [net] Received Message
Feb 22 13:17:52 wirenboard-ABOON5CN daemon.info wb-mqtt-confed[21073]: [MQTT] DEBUG: [net] logic got msg on ibound
Feb 22 13:17:52 wirenboard-ABOON5CN daemon.info wb-mqtt-confed[21073]: [MQTT] DEBUG: [net] received pingresp
Feb 22 13:17:52 wirenboard-ABOON5CN daemon.info wb-mqtt-confed[21073]: [MQTT] DEBUG: [net] logic waiting for msg on ibound
Feb 22 13:18:02 wirenboard-ABOON5CN daemon.info wb-mqtt-confed[21073]: [MQTT] DEBUG: [pinger] keepalive sending ping
Feb 22 13:18:02 wirenboard-ABOON5CN daemon.info wb-mqtt-confed[21073]: [MQTT] DEBUG: [net] Received Message
Feb 22 13:18:02 wirenboard-ABOON5CN daemon.info wb-mqtt-confed[21073]: [MQTT] DEBUG: [net] logic got msg on ibound
Feb 22 13:18:02 wirenboard-ABOON5CN daemon.info wb-mqtt-confed[21073]: [MQTT] DEBUG: [net] received pingresp
Feb 22 13:18:02 wirenboard-ABOON5CN daemon.info wb-mqtt-confed[21073]: [MQTT] DEBUG: [net] logic waiting for msg on ibound
Feb 22 13:18:12 wirenboard-ABOON5CN daemon.info wb-mqtt-confed[21073]: [MQTT] DEBUG: [pinger] keepalive sending ping
Feb 22 13:18:12 wirenboard-ABOON5CN daemon.info wb-mqtt-confed[21073]: [MQTT] DEBUG: [net] Received Message
Feb 22 13:18:12 wirenboard-ABOON5CN daemon.info wb-mqtt-confed[21073]: [MQTT] DEBUG: [net] logic got msg on ibound
Feb 22 13:18:12 wirenboard-ABOON5CN daemon.info wb-mqtt-confed[21073]: [MQTT] DEBUG: [net] received pingresp
Feb 22 13:18:12 wirenboard-ABOON5CN daemon.info wb-mqtt-confed[21073]: [MQTT] DEBUG: [net] logic waiting for msg on ibound
Feb 22 13:18:22 wirenboard-ABOON5CN daemon.info wb-mqtt-confed[21073]: [MQTT] DEBUG: [pinger] keepalive sending ping
Feb 22 13:18:22 wirenboard-ABOON5CN daemon.info wb-mqtt-confed[21073]: [MQTT] DEBUG: [net] Received Message
Feb 22 13:18:22 wirenboard-ABOON5CN daemon.info wb-mqtt-confed[21073]: [MQTT] DEBUG: [net] logic got msg on ibound
Feb 22 13:18:22 wirenboard-ABOON5CN daemon.info wb-mqtt-confed[21073]: [MQTT] DEBUG: [net] received pingresp
Feb 22 13:18:22 wirenboard-ABOON5CN daemon.info wb-mqtt-confed[21073]: [MQTT] DEBUG: [net] logic waiting for msg on ibound
Feb 22 13:18:32 wirenboard-ABOON5CN daemon.info wb-mqtt-confed[21073]: [MQTT] DEBUG: [pinger] keepalive sending ping
Feb 22 13:18:32 wirenboard-ABOON5CN daemon.info wb-mqtt-confed[21073]: [MQTT] DEBUG: [net] Received Message
Feb 22 13:18:32 wirenboard-ABOON5CN daemon.info wb-mqtt-confed[21073]: [MQTT] DEBUG: [net] logic got msg on ibound
Feb 22 13:18:32 wirenboard-ABOON5CN daemon.info wb-mqtt-confed[21073]: [MQTT] DEBUG: [net] received pingresp
Feb 22 13:18:32 wirenboard-ABOON5CN daemon.info wb-mqtt-confed[21073]: [MQTT] DEBUG: [net] logic waiting for msg on ibound
Feb 22 13:18:42 wirenboard-ABOON5CN daemon.info wb-mqtt-confed[21073]: [MQTT] DEBUG: [pinger] keepalive sending ping
Feb 22 13:18:42 wirenboard-ABOON5CN daemon.info wb-mqtt-confed[21073]: [MQTT] DEBUG: [net] Received Message
Feb 22 13:18:42 wirenboard-ABOON5CN daemon.info wb-mqtt-confed[21073]: [MQTT] DEBUG: [net] logic got msg on ibound
Feb 22 13:18:42 wirenboard-ABOON5CN daemon.info wb-mqtt-confed[21073]: [MQTT] DEBUG: [net] received pingresp
Feb 22 13:18:42 wirenboard-ABOON5CN daemon.info wb-mqtt-confed[21073]: [MQTT] DEBUG: [net] logic waiting for msg on ibound
Feb 22 13:18:52 wirenboard-ABOON5CN daemon.info wb-mqtt-confed[21073]: [MQTT] DEBUG: [pinger] keepalive sending ping
Feb 22 13:18:52 wirenboard-ABOON5CN daemon.info wb-mqtt-confed[21073]: [MQTT] DEBUG: [net] Received Message
Feb 22 13:18:52 wirenboard-ABOON5CN daemon.info wb-mqtt-confed[21073]: [MQTT] DEBUG: [net] logic got msg on ibound
Feb 22 13:18:52 wirenboard-ABOON5CN daemon.info wb-mqtt-confed[21073]: [MQTT] DEBUG: [net] received pingresp
Feb 22 13:18:52 wirenboard-ABOON5CN daemon.info wb-mqtt-confed[21073]: [MQTT] DEBUG: [net] logic waiting for msg on ibound
Feb 22 13:19:02 wirenboard-ABOON5CN daemon.info wb-mqtt-confed[21073]: [MQTT] DEBUG: [pinger] keepalive sending ping
Feb 22 13:19:02 wirenboard-ABOON5CN daemon.info wb-mqtt-confed[21073]: [MQTT] DEBUG: [net] Received Message
Feb 22 13:19:02 wirenboard-ABOON5CN daemon.info wb-mqtt-confed[21073]: [MQTT] DEBUG: [net] logic got msg on ibound
Feb 22 13:19:02 wirenboard-ABOON5CN daemon.info wb-mqtt-confed[21073]: [MQTT] DEBUG: [net] received pingresp
Feb 22 13:19:02 wirenboard-ABOON5CN daemon.info wb-mqtt-confed[21073]: [MQTT] DEBUG: [net] logic waiting for msg on ibound
Feb 22 13:19:12 wirenboard-ABOON5CN daemon.info wb-mqtt-confed[21073]: [MQTT] DEBUG: [pinger] keepalive sending ping
Feb 22 13:19:12 wirenboard-ABOON5CN daemon.info wb-mqtt-confed[21073]: [MQTT] DEBUG: [net] Received Message
Feb 22 13:19:12 wirenboard-ABOON5CN daemon.info wb-mqtt-confed[21073]: [MQTT] DEBUG: [net] logic got msg on ibound
Feb 22 13:19:12 wirenboard-ABOON5CN daemon.info wb-mqtt-confed[21073]: [MQTT] DEBUG: [net] received pingresp
Feb 22 13:19:12 wirenboard-ABOON5CN daemon.info wb-mqtt-confed[21073]: [MQTT] DEBUG: [net] logic waiting for msg on ibound
Feb 22 13:19:22 wirenboard-ABOON5CN daemon.info wb-mqtt-confed[21073]: [MQTT] DEBUG: [pinger] keepalive sending ping
Feb 22 13:19:22 wirenboard-ABOON5CN daemon.info wb-mqtt-confed[21073]: [MQTT] DEBUG: [net] Received Message
Feb 22 13:19:22 wirenboard-ABOON5CN daemon.info wb-mqtt-confed[21073]: [MQTT] DEBUG: [net] logic got msg on ibound
Feb 22 13:19:22 wirenboard-ABOON5CN daemon.info wb-mqtt-confed[21073]: [MQTT] DEBUG: [net] received pingresp
Feb 22 13:19:22 wirenboard-ABOON5CN daemon.info wb-mqtt-confed[21073]: [MQTT] DEBUG: [net] logic waiting for msg on ibound
Feb 22 13:19:32 wirenboard-ABOON5CN daemon.info wb-mqtt-confed[21073]: [MQTT] DEBUG: [pinger] keepalive sending ping
Feb 22 13:19:32 wirenboard-ABOON5CN daemon.info wb-mqtt-confed[21073]: [MQTT] DEBUG: [net] Received Message
Feb 22 13:19:32 wirenboard-ABOON5CN daemon.info wb-mqtt-confed[21073]: [MQTT] DEBUG: [net] logic got msg on ibound
Feb 22 13:19:32 wirenboard-ABOON5CN daemon.info wb-mqtt-confed[21073]: [MQTT] DEBUG: [net] received pingresp
Feb 22 13:19:32 wirenboard-ABOON5CN daemon.info wb-mqtt-confed[21073]: [MQTT] DEBUG: [net] logic waiting for msg on ibound
Feb 22 13:19:42 wirenboard-ABOON5CN daemon.info wb-mqtt-confed[21073]: [MQTT] DEBUG: [pinger] keepalive sending ping
Feb 22 13:19:42 wirenboard-ABOON5CN daemon.info wb-mqtt-confed[21073]: [MQTT] DEBUG: [net] Received Message
Feb 22 13:19:42 wirenboard-ABOON5CN daemon.info wb-mqtt-confed[21073]: [MQTT] DEBUG: [net] logic got msg on ibound
Feb 22 13:19:42 wirenboard-ABOON5CN daemon.info wb-mqtt-confed[21073]: [MQTT] DEBUG: [net] received pingresp
Feb 22 13:19:42 wirenboard-ABOON5CN daemon.info wb-mqtt-confed[21073]: [MQTT] DEBUG: [net] logic waiting for msg on ibound
Feb 22 13:19:52 wirenboard-ABOON5CN daemon.info wb-mqtt-confed[21073]: [MQTT] DEBUG: [pinger] keepalive sending ping
Feb 22 13:19:52 wirenboard-ABOON5CN daemon.info wb-mqtt-confed[21073]: [MQTT] DEBUG: [net] Received Message
Feb 22 13:19:52 wirenboard-ABOON5CN daemon.info wb-mqtt-confed[21073]: [MQTT] DEBUG: [net] logic got msg on ibound
Feb 22 13:19:52 wirenboard-ABOON5CN daemon.info wb-mqtt-confed[21073]: [MQTT] DEBUG: [net] received pingresp
Feb 22 13:19:52 wirenboard-ABOON5CN daemon.info wb-mqtt-confed[21073]: [MQTT] DEBUG: [net] logic waiting for msg on ibound
Feb 22 13:20:02 wirenboard-ABOON5CN daemon.info wb-mqtt-confed[21073]: [MQTT] DEBUG: [pinger] keepalive sending ping
Feb 22 13:20:02 wirenboard-ABOON5CN daemon.info wb-mqtt-confed[21073]: [MQTT] DEBUG: [net] Received Message
Feb 22 13:20:02 wirenboard-ABOON5CN daemon.info wb-mqtt-confed[21073]: [MQTT] DEBUG: [net] logic got msg on ibound
Feb 22 13:20:02 wirenboard-ABOON5CN daemon.info wb-mqtt-confed[21073]: [MQTT] DEBUG: [net] received pingresp
Feb 22 13:20:02 wirenboard-ABOON5CN daemon.info wb-mqtt-confed[21073]: [MQTT] DEBUG: [net] logic waiting for msg on ibound
Feb 22 13:20:12 wirenboard-ABOON5CN daemon.info wb-mqtt-confed[21073]: [MQTT] DEBUG: [pinger] keepalive sending ping
Feb 22 13:20:12 wirenboard-ABOON5CN daemon.info wb-mqtt-confed[21073]: [MQTT] DEBUG: [net] Received Message
Feb 22 13:20:12 wirenboard-ABOON5CN daemon.info wb-mqtt-confed[21073]: [MQTT] DEBUG: [net] logic got msg on ibound
Feb 22 13:20:12 wirenboard-ABOON5CN daemon.info wb-mqtt-confed[21073]: [MQTT] DEBUG: [net] received pingresp
Feb 22 13:20:12 wirenboard-ABOON5CN daemon.info wb-mqtt-confed[21073]: [MQTT] DEBUG: [net] logic waiting for msg on ibound
Feb 22 13:20:22 wirenboard-ABOON5CN daemon.info wb-mqtt-confed[21073]: [MQTT] DEBUG: [pinger] keepalive sending ping
Feb 22 13:20:22 wirenboard-ABOON5CN daemon.info wb-mqtt-confed[21073]: [MQTT] DEBUG: [net] Received Message
Feb 22 13:20:22 wirenboard-ABOON5CN daemon.info wb-mqtt-confed[21073]: [MQTT] DEBUG: [net] logic got msg on ibound
Feb 22 13:20:22 wirenboard-ABOON5CN daemon.info wb-mqtt-confed[21073]: [MQTT] DEBUG: [net] received pingresp
Feb 22 13:20:22 wirenboard-ABOON5CN daemon.info wb-mqtt-confed[21073]: [MQTT] DEBUG: [net] logic waiting for msg on ibound
Feb 22 13:20:32 wirenboard-ABOON5CN daemon.info wb-mqtt-confed[21073]: [MQTT] DEBUG: [pinger] keepalive sending ping
Feb 22 13:20:32 wirenboard-ABOON5CN daemon.info wb-mqtt-confed[21073]: [MQTT] DEBUG: [net] Received Message
Feb 22 13:20:32 wirenboard-ABOON5CN daemon.info wb-mqtt-confed[21073]: [MQTT] DEBUG: [net] logic got msg on ibound
Feb 22 13:20:32 wirenboard-ABOON5CN daemon.info wb-mqtt-confed[21073]: [MQTT] DEBUG: [net] received pingresp
Feb 22 13:20:32 wirenboard-ABOON5CN daemon.info wb-mqtt-confed[21073]: [MQTT] DEBUG: [net] logic waiting for msg on ibound
Feb 22 13:20:42 wirenboard-ABOON5CN daemon.info wb-mqtt-confed[21073]: [MQTT] DEBUG: [pinger] keepalive sending ping
Feb 22 13:20:42 wirenboard-ABOON5CN daemon.info wb-mqtt-confed[21073]: [MQTT] DEBUG: [net] Received Message
Feb 22 13:20:42 wirenboard-ABOON5CN daemon.info wb-mqtt-confed[21073]: [MQTT] DEBUG: [net] logic got msg on ibound
Feb 22 13:20:42 wirenboard-ABOON5CN daemon.info wb-mqtt-confed[21073]: [MQTT] DEBUG: [net] received pingresp
Feb 22 13:20:42 wirenboard-ABOON5CN daemon.info wb-mqtt-confed[21073]: [MQTT] DEBUG: [net] logic waiting for msg on ibound
Feb 22 13:20:52 wirenboard-ABOON5CN daemon.info wb-mqtt-confed[21073]: [MQTT] DEBUG: [pinger] keepalive sending ping
Feb 22 13:20:52 wirenboard-ABOON5CN daemon.info wb-mqtt-confed[21073]: [MQTT] DEBUG: [net] Received Message
Feb 22 13:20:52 wirenboard-ABOON5CN daemon.info wb-mqtt-confed[21073]: [MQTT] DEBUG: [net] logic got msg on ibound
Feb 22 13:20:52 wirenboard-ABOON5CN daemon.info wb-mqtt-confed[21073]: [MQTT] DEBUG: [net] received pingresp
Feb 22 13:20:52 wirenboard-ABOON5CN daemon.info wb-mqtt-confed[21073]: [MQTT] DEBUG: [net] logic waiting for msg on ibound
Feb 22 13:21:02 wirenboard-ABOON5CN daemon.info wb-mqtt-confed[21073]: [MQTT] DEBUG: [pinger] keepalive sending ping
Feb 22 13:21:02 wirenboard-ABOON5CN daemon.info wb-mqtt-confed[21073]: [MQTT] DEBUG: [net] Received Message
Feb 22 13:21:02 wirenboard-ABOON5CN daemon.info wb-mqtt-confed[21073]: [MQTT] DEBUG: [net] logic got msg on ibound
Feb 22 13:21:02 wirenboard-ABOON5CN daemon.info wb-mqtt-confed[21073]: [MQTT] DEBUG: [net] received pingresp
Feb 22 13:21:02 wirenboard-ABOON5CN daemon.info wb-mqtt-confed[21073]: [MQTT] DEBUG: [net] logic waiting for msg on ibound
Feb 22 13:21:12 wirenboard-ABOON5CN daemon.info wb-mqtt-confed[21073]: [MQTT] DEBUG: [pinger] keepalive sending ping
Feb 22 13:21:12 wirenboard-ABOON5CN daemon.info wb-mqtt-confed[21073]: [MQTT] DEBUG: [net] Received Message
Feb 22 13:21:12 wirenboard-ABOON5CN daemon.info wb-mqtt-confed[21073]: [MQTT] DEBUG: [net] logic got msg on ibound
Feb 22 13:21:12 wirenboard-ABOON5CN daemon.info wb-mqtt-confed[21073]: [MQTT] DEBUG: [net] received pingresp
Feb 22 13:21:12 wirenboard-ABOON5CN daemon.info wb-mqtt-confed[21073]: [MQTT] DEBUG: [net] logic waiting for msg on ibound
Feb 22 13:21:22 wirenboard-ABOON5CN daemon.info wb-mqtt-confed[21073]: [MQTT] DEBUG: [pinger] keepalive sending ping
Feb 22 13:21:22 wirenboard-ABOON5CN daemon.info wb-mqtt-confed[21073]: [MQTT] DEBUG: [net] Received Message
Feb 22 13:21:22 wirenboard-ABOON5CN daemon.info wb-mqtt-confed[21073]: [MQTT] DEBUG: [net] logic got msg on ibound
Feb 22 13:21:22 wirenboard-ABOON5CN daemon.info wb-mqtt-confed[21073]: [MQTT] DEBUG: [net] received pingresp
Feb 22 13:21:22 wirenboard-ABOON5CN daemon.info wb-mqtt-confed[21073]: [MQTT] DEBUG: [net] logic waiting for msg on ibound
Feb 22 13:21:32 wirenboard-ABOON5CN daemon.info wb-mqtt-confed[21073]: [MQTT] DEBUG: [pinger] keepalive sending ping
Feb 22 13:21:32 wirenboard-ABOON5CN daemon.info wb-mqtt-confed[21073]: [MQTT] DEBUG: [net] Received Message
Feb 22 13:21:32 wirenboard-ABOON5CN daemon.info wb-mqtt-confed[21073]: [MQTT] DEBUG: [net] logic got msg on ibound
Feb 22 13:21:32 wirenboard-ABOON5CN daemon.info wb-mqtt-confed[21073]: [MQTT] DEBUG: [net] received pingresp
Feb 22 13:21:32 wirenboard-ABOON5CN daemon.info wb-mqtt-confed[21073]: [MQTT] DEBUG: [net] logic waiting for msg on ibound
Feb 22 13:21:42 wirenboard-ABOON5CN daemon.info wb-mqtt-confed[21073]: [MQTT] DEBUG: [pinger] keepalive sending ping
Feb 22 13:21:42 wirenboard-ABOON5CN daemon.info wb-mqtt-confed[21073]: [MQTT] DEBUG: [net] Received Message
Feb 22 13:21:42 wirenboard-ABOON5CN daemon.info wb-mqtt-confed[21073]: [MQTT] DEBUG: [net] logic got msg on ibound
Feb 22 13:21:42 wirenboard-ABOON5CN daemon.info wb-mqtt-confed[21073]: [MQTT] DEBUG: [net] received pingresp
Feb 22 13:21:43 wirenboard-ABOON5CN daemon.info wb-mqtt-confed[21073]: [MQTT] DEBUG: [net] logic waiting for msg on ibound
Feb 22 13:21:53 wirenboard-ABOON5CN daemon.info wb-mqtt-confed[21073]: [MQTT] DEBUG: [pinger] keepalive sending ping
Feb 22 13:21:53 wirenboard-ABOON5CN daemon.info wb-mqtt-confed[21073]: [MQTT] DEBUG: [net] Received Message
Feb 22 13:21:53 wirenboard-ABOON5CN daemon.info wb-mqtt-confed[21073]: [MQTT] DEBUG: [net] logic got msg on ibound
Feb 22 13:21:53 wirenboard-ABOON5CN daemon.info wb-mqtt-confed[21073]: [MQTT] DEBUG: [net] received pingresp
Feb 22 13:21:53 wirenboard-ABOON5CN daemon.info wb-mqtt-confed[21073]: [MQTT] DEBUG: [net] logic waiting for msg on ibound
Feb 22 13:22:03 wirenboard-ABOON5CN daemon.info wb-mqtt-confed[21073]: [MQTT] DEBUG: [pinger] keepalive sending ping
Feb 22 13:22:03 wirenboard-ABOON5CN daemon.info wb-mqtt-confed[21073]: [MQTT] DEBUG: [net] Received Message
Feb 22 13:22:03 wirenboard-ABOON5CN daemon.info wb-mqtt-confed[21073]: [MQTT] DEBUG: [net] logic got msg on ibound
Feb 22 13:22:03 wirenboard-ABOON5CN daemon.info wb-mqtt-confed[21073]: [MQTT] DEBUG: [net] received pingresp
Feb 22 13:22:03 wirenboard-ABOON5CN daemon.info wb-mqtt-confed[21073]: [MQTT] DEBUG: [net] logic waiting for msg on ibound
Feb 22 13:22:13 wirenboard-ABOON5CN daemon.info wb-mqtt-confed[21073]: [MQTT] DEBUG: [pinger] keepalive sending ping
Feb 22 13:22:13 wirenboard-ABOON5CN daemon.info wb-mqtt-confed[21073]: [MQTT] DEBUG: [net] Received Message
Feb 22 13:22:13 wirenboard-ABOON5CN daemon.info wb-mqtt-confed[21073]: [MQTT] DEBUG: [net] logic got msg on ibound
Feb 22 13:22:13 wirenboard-ABOON5CN daemon.info wb-mqtt-confed[21073]: [MQTT] DEBUG: [net] received pingresp
Feb 22 13:22:13 wirenboard-ABOON5CN daemon.info wb-mqtt-confed[21073]: [MQTT] DEBUG: [net] logic waiting for msg on ibound
Feb 22 13:22:23 wirenboard-ABOON5CN daemon.info wb-mqtt-confed[21073]: [MQTT] DEBUG: [pinger] keepalive sending ping
Feb 22 13:22:23 wirenboard-ABOON5CN daemon.info wb-mqtt-confed[21073]: [MQTT] DEBUG: [net] Received Message
Feb 22 13:22:23 wirenboard-ABOON5CN daemon.info wb-mqtt-confed[21073]: [MQTT] DEBUG: [net] logic got msg on ibound
Feb 22 13:22:23 wirenboard-ABOON5CN daemon.info wb-mqtt-confed[21073]: [MQTT] DEBUG: [net] received pingresp
Feb 22 13:22:23 wirenboard-ABOON5CN daemon.info wb-mqtt-confed[21073]: [MQTT] DEBUG: [net] logic waiting for msg on ibound
Feb 22 13:22:33 wirenboard-ABOON5CN daemon.info wb-mqtt-confed[21073]: [MQTT] DEBUG: [pinger] keepalive sending ping
Feb 22 13:22:33 wirenboard-ABOON5CN daemon.info wb-mqtt-confed[21073]: [MQTT] DEBUG: [net] Received Message
Feb 22 13:22:33 wirenboard-ABOON5CN daemon.info wb-mqtt-confed[21073]: [MQTT] DEBUG: [net] logic got msg on ibound
Feb 22 13:22:33 wirenboard-ABOON5CN daemon.info wb-mqtt-confed[21073]: [MQTT] DEBUG: [net] received pingresp
Feb 22 13:22:33 wirenboard-ABOON5CN daemon.info wb-mqtt-confed[21073]: [MQTT] DEBUG: [net] logic waiting for msg on ibound
Feb 22 13:22:43 wirenboard-ABOON5CN daemon.info wb-mqtt-confed[21073]: [MQTT] DEBUG: [pinger] keepalive sending ping
Feb 22 13:22:43 wirenboard-ABOON5CN daemon.info wb-mqtt-confed[21073]: [MQTT] DEBUG: [net] Received Message
Feb 22 13:22:43 wirenboard-ABOON5CN daemon.info wb-mqtt-confed[21073]: [MQTT] DEBUG: [net] logic got msg on ibound
Feb 22 13:22:43 wirenboard-ABOON5CN daemon.info wb-mqtt-confed[21073]: [MQTT] DEBUG: [net] received pingresp
Feb 22 13:22:43 wirenboard-ABOON5CN daemon.info wb-mqtt-confed[21073]: [MQTT] DEBUG: [net] logic waiting for msg on ibound
Feb 22 13:22:53 wirenboard-ABOON5CN daemon.info wb-mqtt-confed[21073]: [MQTT] DEBUG: [pinger] keepalive sending ping
Feb 22 13:22:53 wirenboard-ABOON5CN daemon.info wb-mqtt-confed[21073]: [MQTT] DEBUG: [net] Received Message
Feb 22 13:22:53 wirenboard-ABOON5CN daemon.info wb-mqtt-confed[21073]: [MQTT] DEBUG: [net] logic got msg on ibound
Feb 22 13:22:53 wirenboard-ABOON5CN daemon.info wb-mqtt-confed[21073]: [MQTT] DEBUG: [net] received pingresp
Feb 22 13:22:53 wirenboard-ABOON5CN daemon.info wb-mqtt-confed[21073]: [MQTT] DEBUG: [net] logic waiting for msg on ibound
Feb 22 13:23:03 wirenboard-ABOON5CN daemon.info wb-mqtt-confed[21073]: [MQTT] DEBUG: [pinger] keepalive sending ping
Насчет трейса - есть его смысл присылать? У меня процесс не зависает - он все время в таком состоянии.
Спасибо за наводку! Нет, трейс можно не присылать, попробуем разобраться с тем, что есть.
Доброго времени!
Как выяснилось, такая проблема иногда встречалась на контроллерах с большим количеством устройств на вкладке Devices (слишком долго прогружались retained-сообщения MQTT) (UPD: речь идёт о web-интерфейсе контроллера, на серверной стороне всё вроде бы нормально). Интересно, что особенно часто это случалось, если клиентская машина работает под управлением Windows. Таймаут здесь действительно возникает на относительно “ровном” месте, нужно было просто подождать, когда загрузятся все retained-сообщения, прежде чем отмерять таймаут.
Здесь лежит версия homeui, в которой проблема не должна проявляться: https://github.com/contactless/homeui/releases/tag/v1.6.5-beta2.
Как обычно, замечания и предложения приветствуются! Если после установки этой версии ни у кого не возникнет связанных проблем, выложим её в репозиторий.
UPD: ниже лежит ссылка на более свежую бету 1.6.5~beta3, где должна быть исправлена проблема с отображением виджетов на Home и устройств.
Подскажите пожалуйста пользователям windows как обновиться по этой ссылке
Заходите на контроллер, который имеет доступ к интернету, и выполняете комангды:
wget https://github.com/contactless/homeui/releases/download/v1.6.5-beta2/wb-mqtt-homeui_1.6.5.beta2_all.deb
dpkg -i wb-mqtt-homeui_1.6.5.beta2_all.deb
Если подключения нет, смотрите наши статьи Просмотр файлов с компьютера и SSH, скачайте deb-файл на свой комптютер, потом скопируйте на Wirenboard и выполните команду dpkg -i wb-mqtt-homeui_1.6.5.beta2_all.deb
Кстати, в последней прошивке для WB4 я заметил, что контролы на странице Devices стали как-то долго грузиться. Раньше (прошивка была старая, от 15 года) практически моментально появлялись, а теперь вот так:
На локалке чуть побыстрее все (видео снято при коннекте через vpn), но не сильно. Особенно заметно на контроле с WB-MR14 - там прямо каждая релюшечка отдельно прорисовывается.
Подскажите, как откатиться на старую версию, поставил бету и теперь страница с устройствами либо не загружается вообще, либо приходится ждать по несколько минут. как вернуть стабильную версию???
Деень добрый!
Попробуйте браузер Chromium в инкогнито-режиме, поудаляйте ненужные устройства и retained-сообщения. Можно, конечно удалить бету через apt-get remove и поставить сток через apt-get install, но до понедельника не рекомедую вам это делать – можете столкнуться с ещё бОльшими проблемами.
в хроме то как раз всё работает, но мне нужно в мозиле и в internet explorer. как сделать откат корректно. или в понедельник выйдет что-то обновлённое?
Добрый день, нет, не обновление – возможно будет кто-то, кто подскажет, как корректно откатиться. Я попробовал apt-get remove wb-mqtt-homeui && apt-get install wb-mqtt-homeui на Wiren Board 5.6? у меня прошло нормально, но не факт, что у вас всё будет хорошо. Давайте подождем разработчиков.
Доброго времени.
Если не сложно, заведите отдельную тему на форуме и опишите подробнее, что происходит. По идее, бета не должна была повлиять на загрузку страниц интерфейса. Любая информация на эту тему будет крайне полезна, мы попытаемся исправить проблемы.
Тем не менее, для того, чтобы установить стабильную версию wb-mqtt-homeui (1.6.4 на данный момент), введите
apt-get install wb-mqtt-homeui=1.6.4
Здравствуйте! самая большая проблема, которая возникла после установки беты это то, что в мозиле и в internet explorer перестали показываться виджеты. название есть, а параметров, например, таких как температура, напряжение и т.д. нет. на версии 1.6.4 такой проблемы нет. вторая проблема она тоже существенна, но не так как первая на вкладке devices иногда список загружается сразу, иногда частично и приходится обновлять страницу повторно.
Укажите, пожалуйста, версии браузеров.
internet explorer 11.0.9600.18500
mozila firefox 52.0.2
У меня такая же фигня с бетой. Sensor value во всех виджетах сбрасывается после перезагрузки страницы. Если выбрать заново sensor value, то работает. Перезагружаешь страницу - всё пусто. Проверял в Firefox и Chrome на Windows 10
Подтверждаю слова soundbit и lospopadosos, в бете перестали отображаться значения параметров (вкладка Home).
Проверял в Хром и Сафари последних версий на 3-х гаджетах.
Спасибо за сообщения, мы постараемся воспроизвести ошибку и разобраться, в чём дело.
Подскажите, как откатиться на стабильную версию?
