Странные последствия обновления wb5
#21
Понять бы как…
# apt-cache showpkg wb-mqtt-serial
Provides:
1.26.6 -
1.26.5 -
1.26.1 -
1.25 -
#22
А все-таки, есть шанс решить проблему?
На 1.36 странное щелканье модуля WB-MR11 сохраняется. На 1.26.1 все хорошо.
#23
Покажите пожалуйста вывод
cat /var/log/messages | grep serial | tail -n 100
#24
Jan  8 18:45:58 wirenboard-AFKT5EDP user.notice serial: TModbusDevice::ReadRegisterRange(): failed to read 1 input(s) @ 121 of device modbus:172
Jan  8 18:47:57 wirenboard-AFKT5EDP user.notice serial: TModbusDevice::ReadRegisterRange(): failed to read 1 input(s) @ 121 of device modbus:172
Jan  8 18:48:44 wirenboard-AFKT5EDP user.notice serial: TModbusDevice::ReadRegisterRange(): failed to read 1 input(s) @ 121 of device modbus:172
Jan  8 18:49:14 wirenboard-AFKT5EDP user.notice serial: TModbusDevice::ReadRegisterRange(): failed to read 1 input(s) @ 121 of device modbus:172
Jan  8 18:49:39 wirenboard-AFKT5EDP user.notice serial: TModbusDevice::ReadRegisterRange(): failed to read 1 input(s) @ 121 of device modbus:172
Jan  8 18:51:33 wirenboard-AFKT5EDP daemon.info wb-mqtt-confed[3045]: INFO: reloading file: /usr/share/wb-mqtt-confed/schemas/wb-mqtt-serial.schema.json
Jan  8 18:52:21 wirenboard-AFKT5EDP user.notice serial: Warning: no devices defined for port </dev/ttyRS485-2 9600 8 N2 timeout 500> . Skipping.
Jan  8 18:52:21 wirenboard-AFKT5EDP user.notice serial: Init: : setup register <modbus:196:<unspec>: 5> <-- 255
Jan  8 18:52:21 wirenboard-AFKT5EDP user.notice serial: Init: Disable buttons: setup register <modbus:166:<unspec>: 5> <-- 255
Jan  8 18:53:20 wirenboard-AFKT5EDP user.notice serial: ModbusRTU::ReadRegisterRange(): failed to read 1 input(s) @ 121 of device modbus:172: Serial protocol error: request timed out
Jan  8 18:53:44 wirenboard-AFKT5EDP daemon.info wb-mqtt-confed[3045]: INFO: reloading file: /usr/share/wb-mqtt-confed/schemas/wb-mqtt-serial.schema.json
Jan  8 18:55:19 wirenboard-AFKT5EDP user.notice serial: Warning: no devices defined for port /dev/ttyRS485-2 . Skipping.
Jan  8 18:55:34 wirenboard-AFKT5EDP user.notice serial: TModbusDevice::ReadRegisterRange(): failed to read 1 input(s) @ 121 of device modbus:172
Там есть какая-то проблема с чтением WB-MS-THLS, но его отключение не помогает. Пробовал оставлять на линии два устройства (WB-MR11 - рядом с WB и WB-DIM - подключен витой парой 5-7м) - ситуация повторяется
#25
а что будет, если для WB-MRGB выбрать родной темплейт?
#26
Магия…
  • Выключил /dev/ttyRS485-2
  • Выключил WB-MS-THLS
  • Поставил шаблон WB-RGB вместо своего
  • Обновил пакет wb-mqtt-serial
  • Не щелкает…
  • Включил /dev/ttyRS485-2
  • Включил WB-MS-THLS
  • Поставил шаблон WB-DIM вместо WB-RGB
  • Не щелкает…
  • Перезагрузился
  • Не щелкает…
Вчера четко повторялось: поставил 1.36 - щелкает, откатил до 1.26 - не щелкает
Продолжаю наблюдать… Есть идеи, что еще могло повлиять?
