/include/ “skeleton.dtsi”
interrupt-parent = <&icoll>;
aliases {
gpio0 = &gpio0;
gpio1 = &gpio1;
gpio2 = &gpio2;
serial0 = &auart0;
serial1 = &auart1;
spi0 = &ssp0;
spi1 = &ssp1;
cpus {
#address-cells = <0>;
#size-cells = <0>;
cpu {
compatible = "arm,arm926ej-s";
device_type = "cpu";
apb@80000000 {
compatible = "simple-bus";
#address-cells = <1>;
#size-cells = <1>;
reg = <0x80000000 0x80000>;
ranges;
apbh@80000000 {
#size-cells = <1>;
reg = <0x80000000 0x40000>;
ranges;
icoll: interrupt-controller@80000000 {
compatible = "fsl,imx23-icoll", "fsl,icoll";
interrupt-controller;
#interrupt-cells = <1>;
reg = <0x80000000 0x2000>;
dma_apbh: dma-apbh@80004000 {
compatible = "fsl,imx23-dma-apbh";
reg = <0x80004000 0x2000>;
interrupts = <0 14 20 0
13 13 13 13>;
interrupt-names = "empty", "ssp0", "ssp1", "empty",
"gpmi0", "gpmi1", "gpmi2", "gpmi3";
#dma-cells = <1>;
dma-channels = <8>;
clocks = <&clks 15>;
ecc@80008000 {
reg = <0x80008000 0x2000>;
status = "disabled";
gpmi-nand@8000c000 {
compatible = "fsl,imx23-gpmi-nand";
#size-cells = <1>;
reg = <0x8000c000 0x2000>, <0x8000a000 0x2000>;
reg-names = "gpmi-nand", "bch";
interrupts = <56>;
interrupt-names = "bch";
clocks = <&clks 34>;
clock-names = "gpmi_io";
dmas = <&dma_apbh 4>;
dma-names = "rx-tx";
ssp0: ssp@80010000 {
reg = <0x80010000 0x2000>;
interrupts = <15>;
clocks = <&clks 33>;
dmas = <&dma_apbh 1>;
etm@80014000 {
reg = <0x80014000 0x2000>;
pinctrl@80018000 {
#size-cells = <0>;
compatible = "fsl,imx23-pinctrl", "simple-bus";
reg = <0x80018000 0x2000>;
gpio0: gpio@0 {
compatible = "fsl,imx23-gpio", "fsl,mxs-gpio";
interrupts = <16>;
gpio-controller;
#gpio-cells = <2>;
#interrupt-cells = <2>;
gpio1: gpio@1 {
interrupts = <17>;
gpio-controller;
#gpio-cells = <2>;
gpio2: gpio@2 {
interrupts = <18>;
gpio-controller;
#gpio-cells = <2>;
duart_pins_a: duart@0 {
reg = <0>;
fsl,pinmux-ids = <
0x11a2 /* MX23_PAD_PWM0__DUART_RX */
0x11b2 /* MX23_PAD_PWM1__DUART_TX */
fsl,drive-strength = <0>;
fsl,voltage = <1>;
fsl,pull-up = <0>;
auart0_pins_a: auart0@0 {
reg = <0>;
fsl,pinmux-ids = <
0x01c0 /* MX23_PAD_AUART1_RX__AUART1_RX */
0x01d0 /* MX23_PAD_AUART1_TX__AUART1_TX */
0x01a0 /* MX23_PAD_AUART1_CTS__AUART1_CTS */
0x01b0 /* MX23_PAD_AUART1_RTS__AUART1_RTS */
fsl,voltage = <1>;
fsl,pull-up = <0>;
auart0_2pins_a: auart0-2pins@0 {
reg = <0>;
fsl,pinmux-ids = <
0x01e2 /* MX23_PAD_I2C_SCL__AUART1_TX */
0x01f2 /* MX23_PAD_I2C_SDA__AUART1_RX */
fsl,voltage = <1>;
fsl,pull-up = <0>;
gpmi_pins_a: gpmi-nand@0 {
reg = <0>;
fsl,pinmux-ids = <
0x0000 /* MX23_PAD_GPMI_D00__GPMI_D00 */
0x0010 /* MX23_PAD_GPMI_D01__GPMI_D01 */
0x0020 /* MX23_PAD_GPMI_D02__GPMI_D02 */
0x0030 /* MX23_PAD_GPMI_D03__GPMI_D03 */
0x0040 /* MX23_PAD_GPMI_D04__GPMI_D04 */
0x0050 /* MX23_PAD_GPMI_D05__GPMI_D05 */
0x0060 /* MX23_PAD_GPMI_D06__GPMI_D06 */
0x0070 /* MX23_PAD_GPMI_D07__GPMI_D07 */
0x0100 /* MX23_PAD_GPMI_CLE__GPMI_CLE */
0x0110 /* MX23_PAD_GPMI_ALE__GPMI_ALE */
0x0130 /* MX23_PAD_GPMI_RDY0__GPMI_RDY0 */
0x0140 /* MX23_PAD_GPMI_RDY1__GPMI_RDY1 */
0x0170 /* MX23_PAD_GPMI_WPN__GPMI_WPN */
0x0180 /* MX23_PAD_GPMI_WRN__GPMI_WRN */
0x0190 /* MX23_PAD_GPMI_RDN__GPMI_RDN */
0x21b0 /* MX23_PAD_GPMI_CE1N__GPMI_CE1N */
0x21c0 /* MX23_PAD_GPMI_CE0N__GPMI_CE0N */
fsl,voltage = <1>;
fsl,pull-up = <0>;
gpmi_pins_fixup: gpmi-pins-fixup {
fsl,pinmux-ids = <
fsl,drive-strength = <2>;
mmc0_4bit_pins_a: mmc0-4bit@0 {
reg = <0>;
fsl,pinmux-ids = <
0x2020 /* MX23_PAD_SSP1_DATA0__SSP1_DATA0 */
0x2030 /* MX23_PAD_SSP1_DATA1__SSP1_DATA1 */
0x2040 /* MX23_PAD_SSP1_DATA2__SSP1_DATA2 */
0x2050 /* MX23_PAD_SSP1_DATA3__SSP1_DATA3 */
0x2000 /* MX23_PAD_SSP1_CMD__SSP1_CMD */
0x2060 /* MX23_PAD_SSP1_SCK__SSP1_SCK */
fsl,drive-strength = <1>;
fsl,voltage = <1>;
fsl,pull-up = <1>;
mmc0_8bit_pins_a: mmc0-8bit@0 {
reg = <0>;
fsl,pinmux-ids = <
0x0082 /* MX23_PAD_GPMI_D08__SSP1_DATA4 */
0x0092 /* MX23_PAD_GPMI_D09__SSP1_DATA5 */
0x00a2 /* MX23_PAD_GPMI_D10__SSP1_DATA6 */
0x00b2 /* MX23_PAD_GPMI_D11__SSP1_DATA7 */
0x2010 /* MX23_PAD_SSP1_DETECT__SSP1_DETECT */
fsl,voltage = <1>;
fsl,pull-up = <1>;
mmc0_pins_fixup: mmc0-pins-fixup {
fsl,pinmux-ids = <
fsl,pull-up = <0>;
pwm2_pins_a: pwm2@0 {
reg = <0>;
fsl,pinmux-ids = <
0x11c0 /* MX23_PAD_PWM2__PWM2 */
fsl,voltage = <1>;
fsl,pull-up = <0>;
lcdif_24bit_pins_a: lcdif-24bit@0 {
reg = <0>;
fsl,pinmux-ids = <
0x1000 /* MX23_PAD_LCD_D00__LCD_D0 */
0x1010 /* MX23_PAD_LCD_D01__LCD_D1 */
0x1020 /* MX23_PAD_LCD_D02__LCD_D2 */
0x1030 /* MX23_PAD_LCD_D03__LCD_D3 */
0x1040 /* MX23_PAD_LCD_D04__LCD_D4 */
0x1050 /* MX23_PAD_LCD_D05__LCD_D5 */
0x1060 /* MX23_PAD_LCD_D06__LCD_D6 */
0x1070 /* MX23_PAD_LCD_D07__LCD_D7 */
0x1080 /* MX23_PAD_LCD_D08__LCD_D8 */
0x1090 /* MX23_PAD_LCD_D09__LCD_D9 */
0x10a0 /* MX23_PAD_LCD_D10__LCD_D10 */
0x10b0 /* MX23_PAD_LCD_D11__LCD_D11 */
0x10c0 /* MX23_PAD_LCD_D12__LCD_D12 */
0x10d0 /* MX23_PAD_LCD_D13__LCD_D13 */
0x10e0 /* MX23_PAD_LCD_D14__LCD_D14 */
0x10f0 /* MX23_PAD_LCD_D15__LCD_D15 */
0x1100 /* MX23_PAD_LCD_D16__LCD_D16 */
0x1110 /* MX23_PAD_LCD_D17__LCD_D17 */
0x0081 /* MX23_PAD_GPMI_D08__LCD_D18 */
0x0091 /* MX23_PAD_GPMI_D09__LCD_D19 */
0x00a1 /* MX23_PAD_GPMI_D10__LCD_D20 */
0x00b1 /* MX23_PAD_GPMI_D11__LCD_D21 */
0x00c1 /* MX23_PAD_GPMI_D12__LCD_D22 */
0x00d1 /* MX23_PAD_GPMI_D13__LCD_D23 */
0x1160 /* MX23_PAD_LCD_DOTCK__LCD_DOTCK */
0x1170 /* MX23_PAD_LCD_ENABLE__LCD_ENABLE */
0x1180 /* MX23_PAD_LCD_HSYNC__LCD_HSYNC */
0x1190 /* MX23_PAD_LCD_VSYNC__LCD_VSYNC */
fsl,voltage = <1>;
fsl,pull-up = <0>;
spi2_pins_a: spi2@0 {
reg = <0>;
fsl,pinmux-ids = <
0x0182 /* MX23_PAD_GPMI_WRN__SSP2_SCK */
0x0142 /* MX23_PAD_GPMI_RDY1__SSP2_CMD */
0x0002 /* MX23_PAD_GPMI_D00__SSP2_DATA0 */
0x0032 /* MX23_PAD_GPMI_D03__SSP2_DATA3 */
fsl,voltage = <1>;
fsl,pull-up = <1>;
digctl@8001c000 {
compatible = "fsl,imx23-digctl";
reg = <0x8001c000 2000>;
emi@80020000 {
reg = <0x80020000 0x2000>;
dma_apbx: dma-apbx@80024000 {
compatible = "fsl,imx23-dma-apbx";
reg = <0x80024000 0x2000>;
interrupts = <7 5 9 26
19 0 25 23
60 58 9 0
0 0 0 0>;
interrupt-names = "audio-adc", "audio-dac", "spdif-tx", "i2c",
"saif0", "empty", "auart0-rx", "auart0-tx",
"auart1-rx", "auart1-tx", "saif1", "empty",
"empty", "empty", "empty", "empty";
#dma-cells = <1>;
dma-channels = <16>;
clocks = <&clks 16>;
dcp@80028000 {
reg = <0x80028000 0x2000>;
pxp@8002a000 {
reg = <0x8002a000 0x2000>;
ocotp@8002c000 {
compatible = "fsl,ocotp";
reg = <0x8002c000 0x2000>;
axi-ahb@8002e000 {
reg = <0x8002e000 0x2000>;
lcdif@80030000 {
compatible = "fsl,imx23-lcdif";
reg = <0x80030000 2000>;
interrupts = <46 45>;
clocks = <&clks 38>;
ssp1: ssp@80034000 {
reg = <0x80034000 0x2000>;
interrupts = <2>;
dmas = <&dma_apbh 2>;
tvenc@80038000 {
reg = <0x80038000 0x2000>;
apbx@80040000 {
#size-cells = <1>;
reg = <0x80040000 0x40000>;
ranges;
clks: clkctrl@80040000 {
compatible = "fsl,imx23-clkctrl", "fsl,clkctrl";
reg = <0x80040000 0x2000>;
#clock-cells = <1>;
saif0: saif@80042000 {
reg = <0x80042000 0x2000>;
dmas = <&dma_apbx 4>;
power@80044000 {
reg = <0x80044000 0x2000>;
saif1: saif@80046000 {
reg = <0x80046000 0x2000>;
dmas = <&dma_apbx 10>;
audio-out@80048000 {
reg = <0x80048000 0x2000>;
dmas = <&dma_apbx 1>;
dma-names = "tx";
audio-in@8004c000 {
reg = <0x8004c000 0x2000>;
dmas = <&dma_apbx 0>;
dma-names = "rx";
lradc@80050000 {
compatible = "fsl,imx23-lradc";
reg = <0x80050000 0x2000>;
interrupts = <36 37 38 39 40 41 42 43 44>;
spdif@80054000 {
reg = <0x80054000 2000>;
dmas = <&dma_apbx 2>;
dma-names = "tx";
i2c@80058000 {
reg = <0x80058000 0x2000>;
dmas = <&dma_apbx 3>;
rtc@8005c000 {
compatible = "fsl,imx23-rtc", "fsl,stmp3xxx-rtc";
reg = <0x8005c000 0x2000>;
interrupts = <22>;
pwm: pwm@80064000 {
compatible = "fsl,imx23-pwm";
reg = <0x80064000 0x2000>;
clocks = <&clks 30>;
#pwm-cells = <2>;
fsl,pwm-number = <5>;
timrot@80068000 {
compatible = "fsl,imx23-timrot", "fsl,timrot";
reg = <0x80068000 0x2000>;
interrupts = <28 29 30 31>;
clocks = <&clks 28>;
auart0: serial@8006c000 {
compatible = "fsl,imx23-auart";
reg = <0x8006c000 0x2000>;
interrupts = <24>;
clocks = <&clks 32>;
dmas = <&dma_apbx 6>, <&dma_apbx 7>;
dma-names = "rx", "tx";
auart1: serial@8006e000 {
reg = <0x8006e000 0x2000>;
interrupts = <59>;
dmas = <&dma_apbx 8>, <&dma_apbx 9>;
duart: serial@80070000 {
compatible = "arm,pl011", "arm,primecell";
reg = <0x80070000 0x2000>;
interrupts = <0>;
clocks = <&clks 32>, <&clks 16>;
clock-names = "uart", "apb_pclk";
usbphy0: usbphy@8007c000 {
compatible = "fsl,imx23-usbphy";
reg = <0x8007c000 0x2000>;
clocks = <&clks 41>;
ahb@80080000 {
#size-cells = <1>;
reg = <0x80080000 0x80000>;
ranges;
usb0: usb@80080000 {
compatible = "fsl,imx23-usb", "fsl,imx27-usb";
reg = <0x80080000 0x40000>;
interrupts = <11>;
fsl,usbphy = <&usbphy0>;
clocks = <&clks 40>;
